Cleaning a heatsink base?
Raxxath
Through lots of testing and whatnot, the copper base of my D-Tek FuZion has gotten pretty dirty. I figured I'd be able to wash the fingerprints and smudges off, but I'm not having much luck. I've tried isopropyl alcohol and acetone... should I try metal cleaner? Did I manage to ruin my $60 waterblock?
You're not going to get everything off.
When using isopropyl alcohol, try it with a microfiber cloth.
