Has anyone ever seen this
Router: 877w
The user has lost the login password for telnet / ssh etc
We went to rommon changed the config reg to 2142 and rebooted the router
It came in as you would expect at default, I then ran the usual "copy startup-config running-config" and we were in to the config.
I then noticed that this config was different to the config that loads when we boot the router with config reg 2102
All the interfaces where administratively shut down and the 5 hash was different on one of the users. As you can imagine this left us with a bit of head scratching to do. I reset the conf reg and rebooted and the router came back up ok.
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
All I can think is the router boots with a config that is not the startup-config
Router: 877w
