Choice between Chips -- Need Advice
icitrik
I have a choice between a
3.0 that overclocks to 3.45
or a
2.6 that overclocks to 3.25
Which one would give me better performance?
or a
if they are on the same board with the same ram...id go with the 3.45 hands down....now if intel would unlock the multi's and the 3.25 was on a higher FSB id take it...but hands down get the 3.45
But the 3.25 is on a higher FSB
it's running at 1000FSB compaired to 230*4 of the 3.45
or a
If its performance you're after I suggest neither of those cpu's.
An A64 3400+ will give u all the performance & responsiveness you want or need.
