Anyone using a chiiler now? I want to know if there is a chiller small enough to put inside the case or only the big unit outside the case from Hailea? I heard they use aquarium chiller but isnit the same thing?
Im using the EXC-800 Portable 800W Recirculating Liquid Chiller, performance is awesome on my 9960X just need to maintain dewpoint. it is smaller than my desktop. Im sure it can be modded into the base of a large ATX chassis
A $350 Haelia gets you 300 watts of cooling capacity. 300 watts is one high end GPU, let alone adding the CPU. Anything smaller and less expensive, you may as well just do watercooling. The Haelia are large for a reason, and that's to accommodate large fans for quieter cooling. A high wattage compressor inside the space of a computer case, and you're going to be running 2500+ RPM fans even if you have the equivalent of dual 480 radiators.
$800 will get you around 5kW range from S&A... you'll need lot of amps at 240V to run it though.
Looking at a project with one, if it happens I'll have to slap a block on and see what she can do during downtime.
