Chieftec Dragon
vodEVIL
Hi, I just picked one up (http://www.tigerdirect.com/applicat...-details.asp?EdpNo=485243&Sku=DRG-Y&CatId=712) and I am looking for a window kit with a 120 mm in it and a top window with a 92mm fan in it? Where are some cheap realiable places to get some from? Also does anyone know if this case is steel or aluminum? All it says 1mm SECC so I am guessing steel. Also, I plan and sanding it down and useing the spraycan mirror finish tut found on this site.
Best I could find for premodded window kits was Crazy PC have never dealt with them or heard of them so dont know the rep they have. The case is steel and heavy. Not a very good canidate for LAN events.
Did a check at Reseller Ratings on CrazyPC and it would seem they have a decent rep. Might be worth checking out as they do carry top window kits and lots of other stuff for case modding.
Are you serious?
You cannot be serious!
Make your own window and blow hole.
Originally posted by ThePianoMan
maybe he doesnt have the tools
You need tools anyway to put those kits on. How are you going to cut the hole for the window? It doesnt cut itself.
Only thing I dont like about FrozenCPU is thier prices tend to be 5-15% higher than anyone elses. I am finding a serious lack of online resellers for modding equipment here in the US. Seems the Aussies get the best selection out of us all. I think I have found everything I need tho after some searching. Like vodEvil I ordered this Cheiftec case as it was a damn good deal and will be a great base for the mod ideas I had but didnt have the room to do on this old Enlight case I have now.
oh, i thought it gives you a whole new panel
It would seem todays case mods have gone to selling comlete panels and that is what is expected. I am just used to the old way of going to the hardware store and buying a sheet of Lexan then coming home to cut my case panels out and Lexan to fit. Part of the modding thing is to make the PC uniquely yours which is hard to do when everyone else can buy the exact panel you have on your case as well.
I would like to make my own blow hole and window but I can find any thin striping and I want it curved and I cant make curved piece of plexi unless I sand it down. I would just like the window to look professional, something it will just be easier this way. If I can find a good window kit, yes I will just cut it by hand. Thanks for all your guys help so far.
