ChrisJohnson00TA
- Jul 28, 2005
Hello all - looking to build my first PF appliance (3 of them actually).
My goal is a FW/Router that will allow me to do content filtering and snort for about 70 users over 2 different locations/subnets.
I'll have an internet connection (20/10), local lan (GB), and a site to site lan (10/10) plugged into the box. Up to 10 VPN users at a time.
Here is my config:
Supermicro MDB-X9SCL-O
http://www.newegg.com/Product/Product.aspx?Item=N82E16813182252
Intel Pentium G620 Sandy Bridge 2.6ghz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116399
SuperMicro CSE-503-200B
http://www.newegg.com/Product/Product.aspx?Item=N82E16811152107&Tpk=CSE-503-200B
Sansung 4gb 240 pin DDR3 - M391B5273CH0-CH9 (This seems out of stock now, I'll have to find something else - suggestions?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147097
Dynatron P199 low pro cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114075
RSC-RR1U-E16 Riser
Intel GB adapter
And a "Random" 5400 RPM hard drive.
Does anyone see a problem with the above config?
Thanks for the help!
Here is my config:
RSC-RR1U-E16 Riser
Intel GB adapter
