Check my overclock out
Slufa111
My setup is:
AMD X2 4200+ (65W) @ 2.625GHZ on AIR
Gigabyte GA-M59SLI-S5
Patriot Extreme Performance 1 gig DDR-800 @ DDR - 1050
ATI X1950PRO
Check out my CPUZ
http://valid.x86-secret.com/show_oc?id=184331
I don't know why but I can not break the 2.7 spot. I figured if I moved my HT to 3X and my memory to DDR 667 I could get a further overlock but I can't... I dont know why..
By the way this is completely Orthos Stable
Nice overclock though? I am very happy with my ram.
did you try increasing the cpu voltage?
it took a good voltage increase to get my opty to 2.7. completely stable though.
I did, but nothing. I was hoping to hit 2.7 or 2.8 but I am not sure what the problem is. My memory will boot at DDR 800 but not DDR667......why?
my CPU voltage is 1.375.
Also I can get more of an overclock at 10X then 11X....doesnt make sense...
have you tried using a divider ? im at 2.9 ghz stable on air with my athlon x2 4400. with a 133 mhz divider.
maybe its just finicky memory. i have crappy memorythat somehow overclocks pretty decently.
