SJConsultant said:Second, the OEM license is tied to the motherboard, not any other part of the computer. You can in effect replace every single part of the computer *except* the motherboard and still be legal.
SJConsultant said:Barnaby,
You have some misinformation there about how OEM licensing works with MS software.
First, there is a certain list of qualifying hardware parts that a reseller must adhere to when selling OEM copies, I will edit this and post the link once I find it again, but I can tell you that an audio CD does not qualify.
thedude42 said:are you speaking specifically about windows xp and product activation? because otherwise a motherboard upgrade would violate the OEM EULA. i remember the big discussion when XP was still whistler concerning WPA had alot to do with what critical components would be the determining factor in a re-activation case. i remember the network card had alot to do with it as well as the motherboard.
Barnaby said:If that's the case, then Newegg and almost all other retailers are breakin the law. They all suggest buying a cdrom audio cable to meet the hardware requirement. Most of the times they have a deal, and you'll get the cable for free.
The_Terminator said:I have had great success with www.directdeals.com.
They are totally legit, have free shipping, etc.
check out XP Pro with integrated sp2 for $139 by clicking here.
Barnaby said:So if you score an OEM copy, and one day you upgrade your whole rig, what happens when it needs to be re-activated? Does MS deny you the activation?
If that's the case, better to just buy the retail version so you don't have this problem.
tiraides said:Most people would normally steer you towards Newegg first; it's currently at $143 plus shipping there. I got lucky and bought my copy of XP Pro for $145, shipping included, on eBay, but it's too easy these days to get ripped off
The key to finding a cheap copy of Windows XP (any version) is by purchasing the OEM version, which is the full version of the software that Microsoft sells to computer manufacturers at a discount. Keep in mind though that if you buy an OEM version from a store like Newegg, you have to buy some hardware in addition to it.
AMD[H]unter said:I have installed my xp home on my old system, and when I COMPLETELY rebuilt my system from the ground up, I reactiveated online just fine. You shouldn't have any trouble
hulksterjoe said:They could,, Now we all know it doesnt happen but when you install it its tied to that chassis( because we all put the sticker on right?) and motherboard, replacing a mobo due to defect with the same mobo dosent violate the agreement. but upgrading does.. Now how would Ms know that it isnt a replacement and you were forced into an upgrade because they dont make your old board anylonger?
Scheizekopf said:I dont think there is anything stopping you from buying the the Academic version from Newegg.com
Windows XP (Academic) - $82
rusek said:Except fear of eternal damnation for lying.
OldPueblo said:And its an upgrade so he'll have to produce an older version of Windows to validate before the install will continue.
Tiny said:I have about half a dozen Dell Win98 unopened discs laying around, that would work right? Cause all you have to do is pop in the upgrade CD and start installing, the install will only ask you to put the 98 disc in and then it will kick it back out and ask for the upgrade disc again, so it can continue with the install of XP. Or am I missing something?
I dont think so.rusek said:Except fear of eternal damnation for lying.
