why do you insist on buying great parts, and then want a cheap power supply?
The PSU is the most important and should have priority on your money.
suck it up, by 2 GB instead of 3 and put the extra into the PSU.
Corsair right now has a HX520 for $80 After rebate which should work for your system. You can always check out the HX620 for a more future proof solution.
