Back in the old days (pre Windows XP) you couldn't change a PC's name unless you removed it from the domain first. (if it was joined to one that is)
But I came accross a training room full of PC's I had to change their computer names. So for kicks instead of removing it from the Domain first I just decided to rename it and it worked. Reboot and you're done. Otherwise you have to reset the name and dump it into a workgroup, then reboot and log in as a local account and re-join it and reboot again.
I've heard from a server guy here that you shouldn't change it without removing it first because the Kerberos ticket will corrupt and it will have to be re-joined at some point.
So what's the thought here or experiences. Post below.
