I'm just anal about desktop, appeareance as much as performance, with my current settings, unlesss my icon spacing is 60 Horizontal, DVD-RW Drive (X would be shown on 2 lines.
I was going to say it could be done because I used to do it. But when I tried to figure out how I could do it I drew a blank.
On the way to work I remembered.
I have a toolbar on the right side of my screen with all my drives on it. I used to put shortcuts to my optical drives there and I renamed them Plextor, Pioneer etc. and that's how I got around the renaming thing.
this is in My computer... if i were to do what you suggested i would have to put shortcuts using the registry and take out the drives so its not showing?
His explanation is for making shortcuts on a toolbar on on your desktop. It will not change the drive names, as you want. I did more searching, and I still don't think it's possible.
My explanation was a work around I used, not a solution to the original problem. And unless there's some registry hack for it, I doubt there's a way to change the name of your optical drives.
