fasterthanlight
- Nov 22, 2005
How would I set up this, for fun, in my Netgear router?
If your NetGear even supports it. Many consumer products are hard coded to the 192.168.1.x subnet.
Most routers only support private class C networks (192.168.X.X) due to the fact that supporting a private class A would probably overwhelm them.
Just to argue. I have seen a few cheap NetGear and some other weird brand router that could not change the first two octets in the IP.but all of them could be changed.
10 hosts is 10 hosts, whether it's on Class A network or Class C network. Home routers will work fine with a Class A. It's really the number of hosts using that router that makes the difference. As far as addressing goes, all routers see it the same way: binary.
seanx said:Well unless they are expecting people to fully max out a class A with what, some 16 million addresses where as the class C can only do 254.
