CD-RW Problems
TruthInRuin
After a fresh reinstall of XP, my cd burner doesnt want to work. It worked fine before i reistalled, but now... it just doesnt want to work. Not sure what brand it is, but in properties its decribed as "RW-5224" its a 52x24x52x.
If i go to my computer, with a cd in it, it recognizes the cd, but if I try to play it in either Windows Media player, or real player, it wont play. Or if I try to burn a cd with Easy Cd creator 5 platinum it says to make sure thr drive is connected, or try different media/cd and make sure it isnt scratched.
Help please! :(
