CD/DVD drive not recognized
Shzitt
The drive was recognized for around a week, but now will not show up at all under my computer or device manager. Device manager shows 2 primary IDE channels that share the same resources and two secondary IDE channels that share the same resources. Both are listed as not working due to a CODE 12 (not enough resources). The drive detects fine in the bios just not in windows. No bios changes were made prior to it not working.
Running XP PRO service pack 2 on a P5NE-SLI.
This was posted in mobo, but I figured it might go better here.
Any help is greatly appreciated.
I'm having a DVD problem myself - where Windows does not detect a blank CD (but Nero does).
Anyway -
1) is your firmware up to date?
2) did you install anything else after it was working?
3) If it is a bootable drive, can you boot up with it?
Firmware is up to date and the only thing installed after the comp was put together was a few games the wife plays. I have not tried booting the windows CD as I was trying to get around it without having to do a windows install. Strange thing is it shows up fine in the bios and the boot screen that pops up prior to the windows logo, bit once in windows all I get is conflicting IDE channels with no drive.
It will detect the CD drive and boot from a CD if the CD is set as the first boot priority, but the drive does not show up in windows.
If they are IDE, did you check the jumper settings on the back of the drives? They should be set to cable select, or manually set to w/e position they are on the cable (master/slave)
Yep. I checked the jumpers and cables yesterday. Originally had it set to master on the primary IDE port, but changed it to Master on the Secondary IDE port just to make sure the primary IDE port on the MB had not crapped out. Same problem - Can boot from the CD Drive, Drive is detected in BIOS, but not in Windows and the IDE channels (Primary and Secondary) are detected twice and given the same IRQ addresses, but no drive shows in my computer or device mananger.
Device Manager looks like
Primary IDE Channel (IRQ 14)
Secondary IDE Channel (IRQ 15)
Widows gives a CODE 12 - Not enough available resources and places the ! with a circle around it next to the channels.
Thanks for the help so far and if anyone needs more information to help, just ask.
