Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
yep, just splice them together. Most rocker switches are rated at 2 amps, CCFL kits draw something like 350ma. So you could put something like 5 or 6 sets on one switch...
Doesn't allow you to select the color very well of you have different colors tho...
