nightelfmaster
- Mar 28, 2004
the new control center (if u don't have it... http://www.ati.com/products/catalystcontrolcenter/index.html ) doesn't have the options for horizontal and vertical synchronization... at least from spending half an hour looking for it... its default enabled... but with my monitor, haveing it enabled makes the screen fuzzy... is there any way to disable vertical and horizontal synchronization? (its usually under control panel->displays->settings->advanced->display tab->click on monitor->advanced i can't seem to find it in the new drivers...
