Catalyst Control Center Error!
Zidoas
I have never used the CCC ever since it was introduced. Couple of driver releases back I decided to give it a try and ever since then, I've been getting a cli.exe error for every driver version.
I've done drivercleaner and removed all ATI drivers to see if that'd fix the problem and no luck. It installs fine, but whenever my computer starts, it gives a cli.exe error. I can't get CCC to work for me at all :( Any one have any idea on what's going on? And how I can go upon fixing this problem so I can use CCC?
Thanks all in advance.
Don't use it. It's just a resource hog with no real advantage anyways.
Thank you all for the information :)
Problem is solved.
ScYcS: You're right. Nothing to my benefits anyway hahah
