Hello all. I just wanted to post my finding of a bug in the ATI Catalyst 8.3 and the latest 8.4 releases on my HD3870 card.
Basically I have noticed that the black level is much higher in these two driver versions. It happens in the following resolutions only, and the black levels are fine in any resolution not listed here...
1440x900
1600x1000
1600x1200
1680x1050
1776x1000
1920x1200
This bug is manifest when using Vista (I have no idea if this issue shows up in XP). If you have a high resolution LCD monitor of 22" and above, (where the lower contrast ratios show this bug up most) running at any of those resolutions listed, then as Vista loads up, look for a drastic change in black levels as the display switches from the green scrolling loading bar, to the animated Orb, the difference carries on into Windows, and all games and videos, fullscreen or otherwise.
I downloaded all of the previous Catalyst drivers, and have found that anything earlier than 8.3 does NOT have the bug. I have also tried all drivers with and without installing the Catalyst Control Center, and the bug is the same, so it´s nothing to do with the CCC. Also, if you use the MS provided display drivers then this bug is not present.
I have sent this info to ATI, but we all know that they never look at these reports, so I posted it here, in the hopes that enough people notice this bug, and then maybe ATI will get to hear about it!
1440x900
1600x1000
1600x1200
1680x1050
1776x1000
1920x1200
