L0s7_4_Lyf3
- Jul 21, 2005
Where can I get Cat6 qualified RJ-45 connectors for cheap? Places I've found are rediculous, $30 for a 50 pack...
L0s7_4_Lyf3 said:I got a few hundred feet of Cat6 free and you need Cat6 qualified connectors to use them.
All of my cat5 connectors don't crimp right.
I am using the right connectors, but it just doesn't work.SJConsultant said:You *can* use Cat5e crimps on Cat6 cable. Make sure your using the proper crimps i.e. stranded crimps for stranded wire and solid crimps for solid wire.
L0s7_4_Lyf3 said:That doesn't work for me, damn pins don't budge.
And besides, I know my crimper works 100% since it works on all my other cable.
It's either the connectors or the copper conducters are too hard for the pins to punch through.
Anyway, I just went ahead and ordered some Cat6 connectors, so I'll get to find out soon, thanks anyway.
http://www.cyberguys.com/templates/searchdetail.asp?T1=180+0218&sk=MC51419Are you by any chance using 23 Guage Cat6? I have a ton of Cat6 STP and for the life of me I can't find connectors that are shielded. If you are using STP make sure you have shielded Cat6 connectors... that is if you can find them on the market.
