Hello all,
I may be in the market for a new build soon, and I'm looking for a a case with the following features:
1. Good Airflow (not planning to water cool), can mount something like an NH U14S
2. ATX size
3. Can support at least 6 HDDs
4. Hopefully minimalist design and as compact as possible (not looking for RGB or whatever)
-- as a side note, my current Phantom 630 is gaudy and large but I found it for cheap and based on reviews it has really good airflow, so I tolerate it.
5. the cheaper the better?
Planned build is nothing special. Looking at either an X299 or AMD TR, maybe CFL-S 6 core, just 1 GPU and several 3.5 drives.
Upon doing an initial check with Phanteks and Corsair, these only go up to 4 drives on their midtower models.
My go-to case for this kind of application used to be a NZXT Source 210, but in the absence of this in my local market (not from the USA), I'm looking at the Define R5 but worried about thermal performance. Is there anything a little newer and better than this?
Thanks!
2. ATX size
Thanks!
