Case recommendation
brunner
I was interested in buying a custom built water cooling case but it seems that it's pretty hard to find one. I just might have to install one myself. I'm not interested in cutting or any type of modding to my case though. What is the best case which I can use to mount a radiator externally and install a pump/reservoir internally? I'm interested in cases that would cost about $100 to $200. Ijust want to find a case where I can just easily put everything together.
http://swiftnets.com/products/MCB-120-R2.asp
Any case with a 120mm rear fan.
Aerocool Masstige is awesome for mounting a 2 x 120 mm radiator internally!
DE
With the TT Armor or CM stacker, you can install a 2x120 radiator in front without cutting any metal. The gigabyte Aurora 3D may allow a 2x120 rad in the back without mods.
Any case with a 120 exhaust fan should work with an external 1 or 2x120 rad and a radbox, or possibly mounted inside.
All of those cases are in your price range.
-- Rev
chris.c said:
Be careful if you're using 1/2" ID tubing, it'll be a tight fit through a pci slot (found that out with my apex kit), and since it doesn't have much room to bend the options might be limited unless you're willing to drill some holes.
Plus the Armor has pre-cut holes above the rear 12cm fan which are ideal when you're using a radbox, except again they're a little bit too small for 1/2" so I had to file mine out a bit (apart from that I like it a lot).
In other words, for ease of installation, go for a smaller bore W/C kit :)
