Hi, new to the forums and case modding so excuse my ignorance but i have a couple questions. I'm going to start doing some easy mods to my case for visual and performance enhancements and wanted to get some info from the xperts.
Case in question -> http://www.newegg.com/app/ViewProductDesc.asp?description=11-144-017&depa=1
1. I have 2 80mm fans in the front of my case that have a square block mesh behind them leading into the case. I've read that removing those mesh so that the holes are clear will help improve air circulation. Is this true or just an old geeks urban legend?
2. As you can see from the picture I also have a mounting rack/cage for harddrives right behind those 2 80mm fans which also block a good amount of airflow. Would it be safe to say that removing this would help as well? I would mount my drives in the upper 5.25 drive bays using harddrive quiet mounting kits.
3. I have a custom graphic I would like to get on the case window. I wanted to do this with some sort of film like a green window tint or a translucent film. Do you have any suggestions on what to use and how to go about doing it?
Thanks in advance for any suggestions, you guys do a really great job here.
Fixed link
Fixed link
