Case Mod Suggestions!
Pentahedral
To start with heres what I got to mod:
ASPIRE X-Superalien Series Black/Red Aluminum Server Chassis
Case Type: Full-Tower
Color: Black/Red
Material: 1.0mm Aluminum
Drive Bays: 5.25'' x5,3.5''(External) x2, 3.5''(Internal) x5
Expansion Slots: 7
Front Ports: USB2.0 x2,IEEE1394 x1,Mic x1,Speaker x1
Power Supply: 500W
Cooling System: 80mm Blue UV Sensitive LED fans x6
Motherboard Compatibility: ATX-Up to 11"W x 12"L
Dimensions: 18.6"x8"x20.5"
Heres a link to the images, exept the LEDs are green on mine.. http://www.newegg.com/app/ViewProductDesc.asp?description=11-144-004&depa=1
Basically i'm thinking of something to do to set it out from the rest, whether it be lighting, dremeling or what..
Suggest what you might think would look good, and maybe photoshop some pics and post them, I didn't post pics since i'm on a....21K...connection..yes.....but I can look at pics pretty well, and the computer is actually at a university..
So suggest!
Thanks.
i used that case...well the Super version of it.
still have it sitting under my desk collecting dust and used as a parts bin :D
i wanted to mod it because i got disgusted with the look but, i just bought a new case instead. good luck with whatever you do!
Honestly, I think that case model looks like complete garbage. I will never understand why cheap cases with lame, cheap molded plastic bezels sell as wildly as they seem to.
I hold these cases in the same contempt that I used to reserve for ricer cars.
What I would do, is to make an entirely new bezel. Or buy an entirely new (this time, tasteful) case.
Not much else can be done to improve the look of that case.
In the immortal words of Butthead: "You can't polish a turd."
I didn't ask if my case was a piece of shit, but what could I do to change to make it better
What could I do to change the bezel?
