hello to you all i am having difficulty with choosing a case. I have just bought a msi K8NGM2-FID and a AMD Athlon 64 3700+ San Diego i was going to power it with a Enermax Liberty this is how far i have got. The problem i have is i am not sure what case and cooler combo to us. I have looked at the sg-01 and the qpack as i think i can not get the micro fly in the uk. i am leaning to the sg-01 but it seems to be getting rare here. From what i have read the nt06 works well. But other say to use the FX121 but with this combo there dose not seem room for both. Also going to change all the fans to sharkoon ones. The qpack is simpler i will just change the fans and use a 7000 or 7700. Could you lot help witih what combo is better or what cooler works best i am not planing to overclock much as it is going to be my media pc
Thank you
Thank you
