Case For Home Server
Justintoxicated
I need a case that is quite, provides good airflow for hard drives, and holds MANY of them.
right now I have an Antec Mini P180 and it meets all the criteria above except I am out of space. I have 9 drives and want to add 1 or 2 more.
I also have a CM stacker original, it would take them all, but I'd be tempted to buy 3 of those fancy hotswaps since the drives on the original stacker are kind of difficult to remove. That adds $400 in cost though.
Is there a case somewhere in between, honestly, hotswaps would be nice, but the drives are easy enough to remove on the antec for my taste, it just does not hold enough of them.
Alternatively I could just start replacing the 2 existing 1TB drives with new 2TB drives and gain some space that way.
Suggestions?
