Case Fan Positioning
bloodyredd
Hi guys, I would like to ask for suggestions on my case fan positioning. The case that I am using is the Corsair Obsidian 550d and I plan to use corsair fans. I need opinions on it.
So basically the two 120mm fans on the front of the case would be 2 SP120 fans quiet edition fans since the front intake has a very restrictive airflow and a AF120 fan on the bottom and then a AF140 fan on the rear exhaust. All of them are quiet editions. Is it good or not?
I'd say enough air moving in since the front panel of the 550D is closed and the intake is coming from the bottom or the sides of the front panel if I'm not mistaken.
