All right I just finished planning a case in google sketchup. The case is going to be made out of wood and it would have plexi-glass windows on each side except the back. Anyway the case is going to have 2 hardrives I can add more if I want to, 2 cd/dvd drives, a floppy drive, amd athlon 3000+ Venice core @ 2.5 mhz, ati 9600xt all in wonder, a gig of ram, and 8 120mm fans (a lot of fans huh?)There are 8 fans but you cant see them all because one is under the motherboard. I havent started to build the case as of yet I just wanted you guys opinions first. And I have a couple of questions:
Do you think how I positioned the fans would allow the case to have good airflow?
What else should I add to make my case be different?
Do you think I should take out some fans?
If so which ones?
Do you like my design?
Here are the pictures:
http://img514.imageshack.us/img514/4778/computer34fj.jpg
http://img107.imageshack.us/img107/6951/computer42ue.jpg
O i almost forgot to add the two fans on the sides are exhaust fans, the two fans in the front push air in, the two fans on the top push air in, and the fan under the motherboard pushes air around, and the fan down the bottom is an exhaust fan. I know that some of the fans are facing the wrong ways.
And one more thing i have 8 fans in my case and i know that no fan speed controller can handle 8 fans so is it a way to wire two or more fans together so they can be hooked up to one fan speed controller input??
Tell me what you think!!
If so which ones?
