Case choice help...
NoID
I am looking to build a new setup and therefore need a new case. I am looking for a case that meets the following criteria.
- Preferably Aluminum
- Door optional (If it has a door, there has to be atleast 1 unobstructed 5.25 bay for the X-fi Platinum
- It will eventually be SLi, so space is important
- Preferably full tower.
- Well built (I have had a few cases where the screw holes were way off)
Window's are optional.
Thanks in advance.
thermaltake shark is a nice case that should be considered, altho it is a bit pricey
My concern with that case (and other door based cases) is the obstruction of the 5.25 bays. I hope to find a case with at least one unobstructed 5.25 bay
ah i see
