Cardkeeper question
you should need one. the only reason you would need it is 1. you LAN a whole lot 2. you have a heavy card
the latter being the important one. if you lan alot then you probably have a ehavy card that needs the keeper. a light card is highly unlikely to need one.
Alright, thats what I thought. I obviously dont LAN alot, and the card isnt heavy at all. Thanks though man.
