ok i'm ready to replace my old case (it's an older model of that one), which i've had for at least two years now, and i've looked at quite a few cases and have narrowed my choices down to two....
Lian-Li PC-65B
http://www.newegg.com/app/ViewProductDesc.asp?description=11-112-040&depa=1
Cooler Master Praetorian Black PAC-T01-EK
http://www.newegg.com/app/ViewProductDesc.asp?description=11-119-035&depa=1
EDIT (1/19/05): changed my mind about the wave master case, looking at the praetorian now
now i've read a couple of reviews of each and both are solid cases from what i've read. The Lian LI didn't really have any bad sides to it, at least nothing that was worth mentioning. The wave master had some minor issues like the front two intake fans not getting enough air, and that the vent could easily get clogged up with dust......
but anyways i'd really like to know what experiences you guys have had with these cases, if you have had either of them that is...
Lian-Li PC-65B
