Captain Colonoscopy
- Feb 19, 2004
Hello all,
I have been digging through all of the posts on the Symentec STN network and doing a lot of googling but I cannot seem to find the answer to my problem. Wondering if anyone here has run into this issue. Basically we upgraded a client from SAV 10.1.5 to SEP 11.0 before I knew about all the stupid problems with it. It worked "fine", albeit slowly, for about three weeks but then started giving all the network share errors and not letting people login, etc. Tried installing the "hotfix" that Symantec released but that doesn't do anything either. I read posts from many unhappy SEP customers that managed to successfully uninstall SEP and reinstall SAV. This is what I want to do but it won't let me.
Yesterday I uninstalled SEP and SEPM. This was not a very clean process. I ended up having to do the manual removal although I did use the script provided by another poster on the STN forums. Had to kill svchost.exe to delete some SEP service which, incidentally, killed all network access for client workstations again. Somewhere during this process the windows installer service got disabled.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
After I managed to clean up all the left over crap from that uninstall I tried reinstalling SAV Server 10.1 on this server. It goes through the copying motions but then sits there for about 15-20 minutes before it gives the following error:
Setup has not received an update status from 'SERVER'. The server may still be updating, or an error occurred on the server.
Do you want to continue waiting for the server status?
So if I wait it does nothing, if I cancel this it still does nothing. Tried running the MSI for the client just to see what would happen and I got the following error:
Symantec AntiVirus Installer Information
A newer version of this software is already installed on this machine.
If anyone here has run into this problem or has some ideas for me that would be great. I'm not getting any responses from Symantec on their forums and I don't want to call their tech support line. If anyone has had to do that before you know it takes about 3 hours to get a hold of anyone that can actually fix something for you . . . .
Thanks,
![](http://www.hardfolding.com/ftag1.php/mem/148779.png)
Thanks,
