WickedWeasel
- Jul 13, 2004
Fresh WinXP sp2 install. Created the internet connection by going to control panel, network connections and used New connection Wizard to make the broadband connection for "all users". from properties, i unchecked "prompt for name and password, certificate etc."
Then i created a shortcut on the desktop and dragged that shortcut into the STARTUP folder for "all users" to allow for an automatic internet connection after a reboot. the internet connection works fine.
To indicate when the LAN port is connected, i went to control panel, network connection, properties, i checked "show icon in the notification area when connected"
this same method works nicely on a 10 year old computer with an old pci ethernet card. on the old computer, upon bootup, the internet connection is done in 2 secs.
On my new computer, upon bootup i can see a popup that tells me internet connection is dialing, the LAN port is connected instantly, but then it takes another 20secs for the internet connection icon to show up. if i click on the icon to manually connect, it doesn't speed it up, it just gets stuck for 20secs each time after each bootup. it seems like there is some contention there.
what is wrong?
how is everyone else making an automatic internet connection upon bootup?
it this a problem with the gigabyte p35 boards that use the realtek built in LAN?
what is wrong?
