cannot adjust voltage?
mattk
In all my days of overclocking, i've never seen this one before. On the motherboard in my sig, it does not allow me to even adjust the vcore..it's running at 1.29 volts, and i can't even change the manufacturer to user defined or anything...any ideas? Thanks
my mistake, i had 2.9 volts but i meant 1.29
um just a guess, maybe a jumper on your mobo would unlock something like that? not sure though
soyo motherboards generally don't have many overclocking options unless you have the platinum editions. i have a KT600 dragon plus v1.0, and the only setting i can adjust is fsb and multiplier. if you take a look at the specs for you mobo in the link below, it doesn't seem like your board has many options for ocing either.
http://www.soyogroup.com/products/proddesc.php?id=298
ahh thx i needed to see something like that...now i know my options (which are pretty much none). Any p4 mobos you guys can recommend for doing this kinda stuff?
edit: oh yeah, i thought i read somewhere about such a jumper..i'll look into it, maybe check out my manual see if it has that option.
