sitalchauhan
- May 30, 2006
Baslically my brother's laptop is having problems and cannot boot into windows because of a problem with the Ntfs.sys (cannot even boot through safe mode)
I have found the solution, which is to run chkdsk on the NTFS hard drive. Everywhere recommends using the Windows XP install disc to go into the recovery console and run chkdsk through there.
However, my brother lives far away from myself and he does not have access to a WinXP install disc.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I was just wondering could I get him to make a bootable USB (he does not have a floppy drive) using the 'HP USB Disc Format Tool' as in this guide on his friend's laptop:
http://www.bay-wolf.com/usbmemstick.htm
and then could he boot from the usb and run chkdsk at the command prompt?
Or will chkdsk only work on an ntfs drive when in the recovery console using a WinXP disc?
Thanks so much![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks so much
