However, IF, and this is a big IF, they can make it run as cool or cooler, and as fast or faster than DDR 4, then it should be a real winner overall...
Yes, I think it will be a toss-up between making more room for CPU coolers that won't have to have the heat pipes & fins with that silly up-cut to avoid the vertical ram sticks, and the horizontal plane, which will be a little larger since the wiring connectors are moving to the back of the mobo.... and based on the pics I have seen, CAMM's are mounted really close to the mobo surface, so there may or may not be room for dual-sided sticks....It's the same RAM with a different connector. It's gonna be the same speed, maybe a smidge faster if the connector is really better and lets you run faster.
That said, for desktops, I think the issue is these use a lot of horizontal space (parallel to the motherboard) versus a conventional dimm slot, and there's not a lot of room for that, so probably only a single slot (not as bad as it sounds, because camm2 modules can be dual channel, but requires upgrade at once rather than starting with 2 dimms and later buying 2 more on a 4 slot board). I can't tell if camm2 has chips on both sides or only on top? If only on top, it should cool better than tightly packed dimms.
Which in the realm of DDR5 where you can (currently) get 96GB across only two DIMM's is a concept that needs to die. 4x DIMM's is a pain in the ass in the first place.but requires upgrade at once rather than starting with 2 dimms and later buying 2 more on a 4 slot board)
