Ok so I have a laptop motherboard that I am trying to rig up to work since I do not have a charger.
What I am doing:
AC to 24VDC (via standard PC PSU, -12 as ground, +12 as Vcc)
note: +12VDC line is 15AMP and -12VDC line is 0.8AMP
Running the 24VDC through a parallel circuit consisting of two resistors that results in 19.4VDC
note: the laptop needs 19.5VDC to charge/run, but I am pretty sure 0.1V will not matter
Then I slide a 12g copper wire in the center of the laptop DC jack, and a 12g copper wire around the ring of the jack, and hook up the output of the resistor circuit accordingly.
the jack looks like this:
My problem:
Before I put any type of load on the circuit, my multimeter reads 19.4V
Once I attach the laptop to the circuit, my multimeter reads 17.6V
AND
the laptop has no power (ON button does not work, nor the battery charging light turns on.)
any thoughts [H]?
What I am doing:
My problem:
AND
any thoughts [H]?
