CAD Computer Build Help - Cheap
hammerforged
My good friend is looking for a cheap CAD computer for school. Needs to run solid works. Any help is much appreciated!
Computer Aided Design. Solidworks mainly
$600-$400
USA, KY
CPU, MOBO, RAM, HDD, GPU, PSU, Case
None
6) Will you be overclocking?
No
7) 7) What is the max resolution of your monitor? What size is it?
1080P
Within a week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
No specific features needed.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Getting 64bit OS
In that range, a pre built might be the best bet.
Is your 4-600 including OS, or is your OS not included?
Is that GST and ship included?
Requirements
It appears that hd3000 will pass for gpu
Alright, going by the recommendation that Stupid_Newbie says the HD3000 will work with Solidworks... Also since your friend is in school/going to school I am pretty sure Microsoft is still offering discounts on its operating system(s) to students. Search around on Google for more information on that, otherwise add $100 to the price I am about to give you.
$159.99 - Intel Core i3-2125 Sandy Bridge 3.3GHz
$139.99 - ASUS P8Z77-V LX LGA 1155
$89.99 - Hitachi GST Deskstar 7K1000.D HDS721010DLE630 (0F13180) 1TB 7200 RPM
$39.99 - G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
$36.99 - Antec EarthWatts Green EA-380D Green 380W
$49.99 - NZXT Source 220
Total: $501.39
Use these two promo codes to get $15.55 off .. EMCNBHG22 & EMCNBHB237
Well if you aren't including the operating system in on the price, then upgrade the CPU to an i5 2500. It's a quad core w/ HD3000 graphics.
According to solidworks requirements, the HD3000, and HD4000 are approved GPUs. Id say your fine. It was a green check mark, so there was nothing saying any features would be missing.
NCIX has good deals on XFX 7700 right now (Canada). Price is around $110 after MIR.
