Woblin_Goblin
- Jun 6, 2000
I was going to copy the contents of a 2.5 inch laptop hard drive to a regular PC hard drive today at work using partition magic. I was using a adaptor that allows it to be connected to 80 pin EIDE cable. I've done it many times before as imaging PCs is part of my job. Normally I use a image machine to copy the images but in this case it was going very slow so I thought I'd try it using my PC. I've done it before and never had a problem.
I was fiddling around and suspected that my adaptor was bad or had a lose connection. It was working earlier in the day. Long story short, when I powered on the PC a tiny puff of smoke came out of the drive. It's toast, doesn't work at all anymore. Sucks, since I'll have to rebuild the image. Oh well.
I didn't think to check if I had it backwards until now. I know I paid attention to the pin orientation when I connected it but I guess I may have screwed up. Will plugging in a laptop hard drive backwards fry the HD?
I'm thinking about trying it out on a old HD. I hate it when I screw up
