C2Q build check please
batteriesnotincluded
I really hate to do this, but I've not built a tower computer since 2005. (Laptops did just fine for me)
But, here we go: (all prices as of 8:30 7/20 at Newegg)
C2Q Q600: 300
Abit IP35 Pro: 185
8gb Mushkin DDR2 800: 490
EVGA GeForce 8800GTX: 517
2x LiteOn DVD Burner (SATA): $72
Chenbro SR10769: $140 (It's not what I want, but I don't feel like paying twice the amount for a Lian Li eATX size mobo. It's a fucking tank, and weighs about the same.)
PC Power & Cooling 750 Quad Silencer: $200
So far, $1900-ish. Still looking for a good 120mm CPU fan...I'll take suggestions on that as well.
So far I'm rather surprised. My budget was $2500-ish, and I'm $500 under at the moment.
8 GB RAM is massive overkill, really. What will you be doing that would ever need more than 4? I've yet to make full use of 2.
Everything else seems fine. You could go SLI with the other $500 if you're so inclined --- an EVGA NF68-A1/T1 board would be $200 or so, replacing the Abit, and another GTX would put you $500-ish higher.
Not that interested in SLI at the moment.
8gb of RAM would be massive overkill...except....
2005, I had a dual Opteron 254 w/ 4gb of RAM.
I'll have twice the cores, so twice the RAM certainly wouldn't hurt. I realize it doesn't scale like that, but oh well. I could use the Vista excuse as well...but the way I see it, I could either upgrade later on, or take care of it now while I have the money.
I'm looking at gaming, and running several VMWare machines at once. While the gaming might not use the RAM, the VMWare machines will.
What size monitor do you have?
For the CPU HSF, go for the Thermalright Ultra 120 Extreme, with Scythe S-Flex fan.
37" LCD. 1080P.
I bought the Thermalright Ultra, didn't get the extreme though (found out about it after I ordered it...oh well).
moot point now, the P35 chipset doesn't do SLI.
Plus, I'd rather not spend $500 on an extra card, especially if I can just keep that $500, and put whatever the sale of the card I have now gets me, and put it into the next generation.
