I plan on building an external enclosure to fit my watercooling system is...I will have a dual 120mm radiator, pump, and a resivoir contained inside. I hate working with metal, so I'm thinking of making the enclosure out of acrylic glass, which would probably look better anyways.
When I'm cutting the acrylic...what should I use to do it? I hear using a Dremel tool will warp it, because the cutting attachment is turning too fast, thus creating too much heat while cutting it.
What do I need for venitlation? Obviously there will be two holes for the radiator's fans to use, but do I need additional holes in the side for venitlation? Koolance's EXOS and EXOS 2 have holes in the side, but are they required? Also, should I pull air from outside in the enclosure, or pull air from in the enclosure outside?
Is there any way to convert the the fans to 120V AC through some type of power adapter? Having a couple molex connectors hanging out the back would look shitty...having it all wired to a single 120V AC line would be more convienent.
Thanks.
edit: I also see that the EXOS systems don't use a shroud...could I get away with not using a shroud, or a very small one? I don't want to have a huge enclosure.
Thanks.
