Building a gaming system, need advice.
NewEgg has 6 months no payment no intrest, which I'm going to take advantage of.
This is what I have and what I will be ordering once the Intel price cut comes to play.
ASUS P5N32-E SLI Plus LGA 775 NVIDIA nForce 650i SLI
EVGA 640-P2-N825-AR GeForce 8800GTS 640MB GDDR3 PCI
Express x16 SUPERCLOCKED HDCP
Antec NeoPower NeoHE 550 ATX12V 550W Power Supply
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor
BUFFALO Firestix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit
All I'm looking for now is a 400+ GB SATA 3GB HD and a nice case that will allow upgrades in the future.
I already have a DVD/CD burner.
The reason why people here on the forums have disapproved of the GameXStream is that it has ripple or voltage fluctuations. Over time these voltage fluctuations can damage your PC. So rather than take a chance with their high end or even mid-range gaming PC, many people here have avoided that power supply.
But all the reviews that talk about this problem say that it only occurs if it's pushed to it's limits. Thanks for the advice though, at least I'm aware of the problem.
And AK_Warlord that's a nice rig you have there, very solid. But I still say the 320MB 8800GTS is a better buy. More memory doesn't necessarily translate to better performance since the 640MB version will give solid performance at 1600x1200 in certain highly demanding games like FEAR and Oblivion with FSAA and AF maxed out, while the 320MB version will start to choke at that point but at resolutions lower than that, it plays games perfectly the same. But it's your call in the end.
I play all my games at 1280x1024 so high resolution performance is important.
ANd I also going to be using AA and AF all the time.
So far this seems to be the final rig that I will be building.
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply
This is the case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146029
I have 5.1 Logitech Z5500 surround
I have Creative AudigyZS 2 (I heard its identical to X-fi in games)
I have G15 Keyboard + MX518 mouse
and I have Samsung 930B DVI monitor which I love and I think is a great gaming monitor.
I play games like fat kid eat cake.
====>Any particular reason for this over the P5N-E SLI? It is the exact same board minus the chipset heatpipe cooling, which has been shown on the P5N32-E SLI Plus to NOT be adequate for overclocking. Thus, you will need to upgrade it anyways. The performance of the two boards is 101% identical. $70 difference.
====>Honestly, no point in paying more for this over the standard GTS 640MB. Overclocking is a matter of downloading nTune and moving a slider a couple inches to the right. Even when you OC on your own EVGA covers you with lifetime warranty. $40 difference absolutely not worth it under any circumstances.
====>500W is the minimum for a modern gaming system. You could bump this up to the 620W model at no additional cost simply by making the changes recommended above. Corsair is solid, however, so stick with this either way. You'd pay $30 more for the CMPSU-620HX. I would not label this a high priority.
====>Nothing really wrong with this, but know that you are paying $88 more than you would for the E6400 when the latter CPU has been shown to go farther in overclocking, on average. And what will it take to overclock on your board? Changing a single number in your BIOS, that's all. Practically every E6400 is capable of clocking past 3 ghz, totally stable on stock cooling and voltage.
====>Budget memory. That is good. That is what I like to see. RAM is easily the least important of the "big 4" so there is no reason to spend over $150 on 2 gigs, which is the standard amount every gaming rig should have. But your brand isn't well known, and RAM compatibility issues are known to exist with the latest generation of nForce 6 series mobos. Better solution? Check this out: http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034 Rock solid memory from the most trusted manufacturer in the business for $150 after rebate.
This is the case http://www.newegg.com/Product/Product.aspx?Item=N82E16811146029
====>It most definitely is not, as someone who went from your exact sound card to the X-Fi Extreme Music. Get the X-fi and prepare to be blown away. The hype is real. Every pro gamer is using this. Would you like to hear your opponents coming from miles away in any FPS?
I have G15 Keyboard + MX518 mouseand I have Samsung 930B DVI monitor which I love and I think is a great gaming monitor.
My suggestions could save you $168. Do you know the price difference between the EVGA GTS Superclocked and GTX? It's $170 (taking off $30 rebates for both).
You could upgrade to the most powerful desktop video processor ever created with absolutely no loss of performance anywhere else.
The video processor is the single most important component of a current gaming system, by far.
And the Corsair HX 520 is cheapest at ZZF for around $100 shipped after a mail in !
====>Budget memory. That is good. That is what I like to see. RAM is easily the least important of the "big 4" so there is no reason to spend over $150 on 2 gigs, which is the standard amount every gaming rig should have. But your brand isn't well known, and RAM compatibility issues are known to exist with the latest generation of nForce 6 series mobos. Better solution? Check this out: http://www.newegg.com/Product/Product.aspx?Item=N82E16820145 034 Rock solid memory from the most trusted manufacturer in the business for $150 after rebate.
Actually, the newer batch of E6300/E6400's haven't been able to OC better than the E6600's. People are assuming its because they're now true allendale cores, instead of conroes. There are several threads on this in the intel cpu subforum. Though, they can still reach 3-3.2ghz, and the extra 2mb cache isn't so important right now. However, if you have the budget, you might as well go for the e6600.
Buffalo is pretty well known in the enthusiast market, especially these Firestix. They use the micron chips that everyone is in love with, so they oc very nicely (ddr2-1000); and if you don't need to oc, they can be tightened to 4-4-4-12 @ ddr2-800. Though, you don't really need highly oc'able ram with a cpu that has a high multiplier like the e6600. still some nice ram, since you can lower the timings. I'd go with these over corsair vs sticks any day if I'm building a gaming rig. They'll work fine in the nF6 series boards. Just make sure you don't get the 680i board that likes to kill ram, lol (regardless of brand; I think it was the first rev of the evga board, hehe).
I either agree or have no opinion on the rest.
This is the revised list;
NZXT Zero Black/Silver Aluminum ATX Full Tower Computer Case - Retail
ASUS P5N-E SLI LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
EVGA 640-P2-N821-AR GeForce 8800GTS 640MB GDDR3 PCI Express x16 HDCP Video Card - Retail
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
BUFFALO Firestix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model FSX800D2C-K2G - Retail
Western Digital Caviar SE16 WD3200KSRTL 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - Retail
