Build Plan with NCASE
Peter_364
OK so this is my plan, Hopefully I am going to put all these in the other case first befor the NCASE arrives and then when it does i will be ready, although I'm not sure about spending lots on that power supply and other case when i'm just gunna sell it afterwards?
Please post comments on compatibility etc,
sorry the list is mucked up I inserted it dirctly from excel and will try and fix it
NCASE M1 £300.00
Part Phase 1 price Comments?
Case Bitfenix Phenom £75.00 seems suitible
MB ASUS MAX VI £160.00 PWM fan headers mean might have to put the swiftech splitter in
CPU INTEL i7 4770K £225.00 Comments?
GPU GTX 780 Ti £555.00 Asus
RAM Crucial VLP £120.00 Required for NCASE size
PSU Silverstone SFX 60
SSD 840 EVO 500GB £185.00 great value
LC Swiftech H220 £130.00 Extendable etc internal res
Fan NB-eLoop B12-PS £18.00 :eek: eLoops
Fan NB-BSP PE-P 92mm £12.00 as an extra
Total Phase 1 £1,563.00
Phase 2
W-Block EK-Acetal GPU £75.00 YEP
Tubing EK-3/8" ID £25.00 IT’S A TUBE, Clear or black
Coolant Ekoolant £5.00 Could go red to match colour scheme
RES Plug Monsoon £3.00 yeah this is connected to redirecting it
Fittings 6 Monsoon £30.00 Think about 90* ones might be more practicle
Tool Tube cutter £10.00 Monsoon one?
Think about redirecting fill port-Yea this might be difficult, hard tubes? How to mount the fill port at the top?
Total Phase 2 £148.00
Total Phase 1&2 £1,711.00
Phase 3 Pt 1
Pump Swiftech MCP 350 £50.00 Unsure of fitting, consider EK/Swiftech
Pt 2
W-Block EK-Acetal FULL-M £80.00 Yay hopefully there will be enough space for good airflow
Extra-tubes etc £30.00 Just an estimate
Total Phase 3 £160.00
Total Phase 2+3 £308.00
Total all phases £1,871.00
You'll have to choose either a full ATX PSU or a full-length GPU - you can't fit both in M1 unless the PSU is 140mm or less in height and non-modular.
See this post for images of M1 with full PSU and short GPU.
edit: ah, you obviously plan to swap the PSU out for M1. Please ignore my post;)
Yeah the ATX PSU is for the Bitfenix case which apparently doesn't support SFX PSUs and hopefully the seasonic 600W PSU will be out by the time I get my NCASE
Actually the SFX PSU's from silverstone come with a mounting brakcet for atx mounting. That would be a viable option to cut down on having to reinvest in a new PSU, and then only leaves for the case to be sold. once you have/acquire your NCASE.
Thats awesome thanks :)
I might also change all my fittings to the monsoon 90 degree ones
