Build my loop.
delvryboy
I'm looking to dive into some basic water cooling. This is pretty much going to be an eye candy build.
There will be no dedicated GPU; CPU is a A8-3870k. Socket FM1. Colors are going to be UV green and purple, so I'd like to aim there for tubing. I'd like to keep it under $200.
This is the case, so I think have room at the top for the rad. and fans. I originally bought it with the intentions of using a H2O 620:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227
Are you looking for a custom built loop? a self contained cooler might be perfect for you as you will not have a GPU in the loop.
Example:
http://www.antec.com/Believe_it/product.php?id=NzA0MzcwJjE3&lan=us
For looks I would use a daul 120MM rad on the top,
http://www.dangerden.com/store/black-ice-xtremeii-radiator.html
CPU nice DD nickel block:
http://www.dangerden.com/store/dd-m6-nickel-cpu-block-lga-2011-1155-1156-1366-775.html
1/2" UV tubing always looks sexy!
http://www.dangerden.com/store/uv-reactive-tubing/
To top it off a monsoon res+pump is attractive:
http://www.dangerden.com/store/bay-style-reservoirs/
Oh and blinky RAM is good too:
http://www.crucial.com/store/partspecs.aspx?IMODULE=BL25664TN1608
Already have a h2o 620, looking for something custom. Maybe a slim 2x 120? I'd like to use a push configuration exhausting out the top, since I won't have any added gpu heat.
Good luck building a custom loop under $200. Can be done but not with the best components.
