aboutblank
- Apr 7, 2006
I want a dedicated storage box in my home. Here are the requirements:
Gigabit
Hardware RAID 5
Linux based (I like Ubuntu)
SATA
Not too bad if you ask me. Here's my solutions:
Option 1:
Thecus N5200 NAS - $640
*Convenient little box
*Easy Setup
*Pricey
*I know it will work
*Gets 40 MB/s write and 50 MB/s read speeds. I think that's great.
Option 2:
Build my own server. From what people tell me, I need a 3ware card to have *true* hardware raid. I have a Promise TX4310 right now, and linux sees 3 drives because apparently it's fakeRaid (driver driven).
3ware 9650SE 4-port - $335
Compatibility List
Intel D975XBX2 - $147
That's the cheapest mobo that is on the compatibility list. It's an open box, and the retail one is $200.
LGA 775 Celeron D @ 3 ghz - $50
The cheapest LGA 775 proc.
The hardware compatibility list for the 3ware card is pretty short. There are two mobos using the Intel 975X chipset, so do you think if I bought the $120 DFI board with the same chipset, it would work?
My Dad and I were talking about how the actual PC might be more modular and could be used later. I want this box to stay together without maintenance until SATA dies. I want to be able to upgrade/replace the drives, resize the array, etc. At that time, both of these setups will be obsolete.
So there's the two options. Which would you go with and why?
Thanks for your time!
Gigabit
Hardware RAID 5
SATA
Option 1:
*Easy Setup
*Pricey
Option 2:
Compatibility List
