I'm volunteering at a small non-profit.
They have a T1 internet connection, and I think it is suffering from massive buffer bloat.
The T1 endpoint (not sure of the terminology Re: T1 equipment) feeds an ethernet cable that goes into the WAN port of a Linksys BEFSX41 (HW version 2.1)
several times, when the ping times were reasonable for an extended period of time, (less than about 50ms) I would start a speedtest.net test of internet speed. As soon as it started ping times would spike into the 400-600ms range, as well as get timed out pings. Additionally, the speedtest.net graph of upload speed would show a massive spike to 5Mb/s or so before sharply declining and coming out to an average of about 1.2Mb/s
This is the first time I have experienced a problem like this myself, but it sounds like buffer bloat. Linksys has apparently never published an updated firmware for these devices, so I don't have that option.
What I would like to know is:
If you deal with a T1 line:
1. Do ping times vary widely when saturating upload link, vs saturating download link, vs nominal to minimal usage
2. What are you using for a NAT/Firewall/Router
3. Do you think that replacing the Linksys with a Cisco ASA model would fix this issue
4. Do you know if Cisco devices support CoDel (Controlled Delay the protocol designed to minimize buffer bloat issues?
Thanks for your help.
Code:
ping www.google.com -n 100
(snip)
Ping statistics for 74.125.225.82:
Packets: Sent = 100, Received = 97, Lost = 3 (3% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 537ms, Average = 172ms
