BSOD when OC'ing
cnick79
I'm trying to OC my P4 3.4ghz Northwood. When I set the FSB to 230mhz I have a hard time booting to windows without seeing some sort of BSOD. I know it's not my memory because I relaxed the timings to 3-4-4-8 and even set the cpu:ram ratio to 5:4. I would find it hard to believe that's the max my CPU could go. Are there any other tricks I can try to push it more? I also locked my agp/pci. I do have 1 raptor drive setup as a boot drive, could this be the problem?
you should try incrementally increasing the Vcore of the CPU until the computer gets stable again.
...looking for OC notebook...
same mobo as you, but with a 3.2E
this is what I ran stable: everything @ 1:1 ...each setting below
Hyper Threadding == OFF
passed Futuremark2k5, farcry & D3 benches
FSB Vcore
225 - stock
230 - stock
235 - 1.41v (increased by 1 notch) modified CPU throttling in BIOS from 50% -> 75% -stable
240 - 1.4625v
I never got it to stick @ 250FSB. maybe i should have laid off the 1:! ratio
hyper Threadding == ON
FSB Vcore
230 - 1.41v
235 - 1.4375v
...never tested further because I don't run HT in games.
hopefully this gives you a bit on insight into your board. It was my absolute favorite to OC on.
I had my CPU voltage over 1.60. I think I had it at 1.625. It's stock voltage is 1.50-1.55 (one of them). I did a search on other people with the same problem and couldn't find a clear solution. Some people mentioned it could be the power supply not providing enough power at times. I would hope this isn't the case because I have an Antec TrueControl 550w PS. I do have 4 case fans, 3 HD's, DVD ROM, 12v water pump, floppy drive and a 6800U all sucking power. I'm going to hook some of these items to another PS I have and run dual power and then test it. This way here I'll be able to tell if it's my PS or not. Not sure where to go to next.
My main problem in the beginning was a crappy Ultra X-Connect 500W PSU.
The northwoods can handle a bit higher voltages spectrum than the prescotts. On pressys, you shouldn't go above 1.6... but you have a northwood, so don't worry too much.
These numbers are from my first stint ever of OCing a P4 so I was being very careful.
Well, you have a 17 multi, so 230 x 17 = 3910. Most Northwoods couldn't do that, especially on air cooling. You may be asking too much from your chip.
Yea, I think I am. I bumped it down to 220mhz and now I'm having freezing problems. That's also after I hooked up my video card to another PS to draw power away. The strange thing is CPU-Z is reading my cpu volts lower then my BIOS. I have my cpu volts at 1.60 but cpu-z is reading it around 1.55. I think i'll push it to 1.65v and see how far I can go from there. This is my first time OC'ing and this entire computer project has been nothing but headaches.
Oh, I also have water cooling.
If I remeber correctly, Abit is notorious for undervolting.
I have an Abit IS7 and the voltages I set in the BIOS and the voltages CPU-z read and always different. CPU-z is always lower than the BIOS.
So CPU-Z is more accurate? If that's the case I'll bump up my vcore to 1.65 or 1.675 and should be ok. When I find out my max fsb I can reconnect all my devices to the same power supply and see if I get any freezes or BSOD. If I do then I get a new PS. I'll then reset my mem divider to 1:1 from the current 5:4 and see if my mem likes what it's dealt.
What would be nice if I could run 16x250mhz with 5:4 divider. That would give me 4ghz even and my RAM would be at 200mhz.
