BSoD help!
I recently built a new computer. E6850 Intel Processor, ABIT IP35 PRO motherboard, two gigs of G.Skill RAM (no vista), and an 8800 GTS graphics card. I have recently been getting random blue screens throughout the day for no apparent reason. It's not overheating, my temperatures are fine. I installed the drivers from the CDs that came with the parts. I am also using XP home edition. Any help would be much appreciated.
Corsair HX 620 Watts. I just got blue screened while responding :-/
EDIT: I don't think it's overheating..i asked around and 55 degrees C is standard for a GFX, i ran about 70ish C playing Crysis. My processor is like 20 so that's fine
You should never use the drivers off the cd. Always go and get the newest off the web!
If it's bsod'ing and restarting, turn off automatic restart. Getting the Stop code would be great help in pointing out the problem.
K i tried to install my mobo drivers, and it said my PC does not meet the minimum requirements, it will terminate, then it stopped. I went ahead and got the updated GFX drivers though, what do you recommend me to do?
you downloaded drivers from here?:
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=4&model=382
automatic restart is under system properties, advanced, look for startup and recovery, click setting and uncheck the box for automatic restart.
I got my drivers from there, yes. But i got the ones for the IP35 PRO not just IP35...and thanks for telling me how to turn off system restart. If i blue screen again i will write down the error.
oh, pro, my bad.
UPDATE: I just got blue screened again, first time today. I wrote down the stop error like someone said..
STOP: 0x000000D1
(0x233c0017, 0x00000002, 0x00000000, 0xb9e7716e)
No clue what this means
Manually set the first 4 memory settings for your G.Skill memory. If stock, try 4-4-4-12 @ 2.1v, if overclocked, try 5-5-5-15 @ 2.1v
