Broke my NF7-S
Disarray
I slipped tightening a screw and knocked off a small part from the Mobo. IIIRC it was IC 741. So far everything still works but I'm sure that thing is on there for a reason. Any suggestions on what to do? Can I send it to Abit to have it repaired for a fee? Any way to test it to see what is broken? Any other suggestions you have, throw them out here please.
Abit doesn't cover damage that you do. If you can't solder, find someone who can and have them fix it (assuming no pins were broken off of the IC).
You could alway send a message to Abit, and ask them what that IC does. I'm NOT suggesting that you start an RMA, but just mention to them that it looks damages (explain what it visually looks like) and if its something that you have to worry about. You never know, they might actually be able to pass you up to an engineer that knows what the hell if does.
Never would, nor did I mean to imply that I would rma this board. This is entirley my fault. Just never seen this peice before and do not know what it is.
Where is this part? I can't find IC 741 on my board? Picture?
Ill have to break the machine back down to get the pic's. Ill update later tonite.
Well its not tonite, but here is a shot of the broken part:
That is as clear as I can make it. It is due east of the nut you see in the picture. That puts it between the nut and the CPU socket.
I know the layout and fundamentals of this board fairly well, and even I don't know what it does. Surely there is some feature on the board that cannot function without it, but I would not be concerned. Things that might not work now are:
-S3 or S1 sleep
-Aux ports (game port, onboard ethernet, parallel port, etc)
-Overvoltage protection (although I think that was elsewhere, would have to look at my diagram)
-etc
Thanks for taking the time to reply. If you find out, let me know. Also, if I need to fix it, any suggestions. I can solder but I dont know about something this small. I would be worried about the heat.
That is a surface mount resistor or capacitor. (hard to tell even if you are looking at the part, much less looking at where the part used to be)
As for what it did, if the board seems to work fine without it, it was probably somthing to help with voltage regulation, or EMI or the like.. Because if it were needed to function, obviously it would not still function. It sounds like you got lucky.
==>Lazn
