Hi guys. You have been great in the past for answers so I figured I'd try you guys again.
After being misinformed by my supplier I ordered a CCR1036-8G-2S+ (SFP+ model) under the impression it would support 1.25Gb SFP's. But after recieving them and having no luck. I found with a very little bit of research (yea my bad) that the router does not support 1.25G sfp's
I do have a couple other Mikrotik products with SFP ports which link up in the lab.
260GS and RB2011UiAS-RM
The question I have, is what's the best method for bridging the fiber to ethernet. Do I just setup a bridge with the SFP port and Ethernet port? Or is there a better method. Forgive my noobness.
Thanks in advance
Peter
Thanks in advance
Peter
