Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Can anyone reference me some cases with a bottom mounted PSU? I know the p180, coolermaster stacker, and lianli v600 have bottom mounted psu's. What else? (preferrably in the under 20 lb range.)
Silverstone tj07 - best case out there and with room for 2 psus. Also, the new Lian Li a10, is bottom mounted and allows for 2 psus. Food for thought. Instead of getting the ridiculous 1KW psus, I would go with a combination of two lower power psus for redundancy, less stress, etc.
I have a tj07, and a LianLi pc201 - both bottom mounted.
